It is currently Sun Jun 29, 2025 3:34 am
PostPosted: Mon Aug 14, 2006 8:05 am
I was just sitting at lunch and thinking about spool clamps (what can I say) and how they are made and used. That made me wonders how spool clamps can be used to attach the top and back if the sides are inside a mold. Are spool clamps only able to be used on a rim outside a mold? What method of top and back attachment do you use?
Philip
aka konacat
PostPosted: Mon Aug 14, 2006 8:08 am
No you can drill holes in your outside mold all the way around the body, then run your spool clamps through the holes.
PostPosted: Mon Aug 14, 2006 8:10 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Good question Phillip. Don't have an answer for you, though I'm sure someone will. I use my go-bar deck, with a caul so I don't damage the top or back.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Aug 14, 2006 8:11 am
I've seen holes drilled in the mold near the sides to allow the spool clamps to pass through. Seems like this would be a pain at glue-up time though, IMHO.
I and others have used go-bars. My setup looks like this:
edit: man these guys post quick!burbank38943.7184606481
PostPosted: Mon Aug 14, 2006 11:43 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
I do it just like Pat, 'cept I glue the back on first...
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Aug 15, 2006 12:43 pm
Terry, where did you get those spool clamps?
PostPosted: Tue Aug 15, 2006 2:16 pm
[QUOTE=burbank] I've seen holes drilled in the mold near the sides to allow the spool clamps to pass through. Seems like this would be a pain at glue-up time though, IMHO.
edit: man these guys post quick![/QUOTE]
PAT, YOU'VE GOT A BIG HOLE IN YOUR BACK PLATE
PostPosted: Wed Aug 16, 2006 4:26 am
[QUOTE=Rod True] [QUOTE=burbank] I've seen holes drilled in the mold near the sides to allow the spool clamps to pass through. Seems like this would be a pain at glue-up time though, IMHO.
Oh, I forgot to mention. It's my combo access/sound port. Needs a little work though, seems I lost some volume.
